here are the factory options
AR9 seats reclining buckets
AU3 power door locks
A01 tinted glass
A31 power windows
A90 power trunk release
BD1 rocker panel molding trim delete
BS1 acoustical insulation pkg
BV8 ornamintation exterior door lock cylinders
BW3 ornamentation extra roof window trim (painted)
BX5 ornamentation exterior moulding roof drip ( painted)
B24 side window reveal moldings (black)
BA8 trim pkg luggage compartment
B71 wheel moldings (colored)
B72 ornamentation exterior molding belt reveal (colered)
B77 ornamentation exterior moldings w/s reveal (colored)
B79 ornamentation exterior rearend
B88 molding body side (custom)
B89 ornamentation exterior molding rr window reveal
B91 exterior molding door edge guard (colored)
B94 ornamentation exterior emblem body var1
CD4 windsheild wiper system (pulse)
CF5 roof sun glass sliding elec
C18 arm and blade wsw
C60 hvac system air conditioner frt man controls
C95 lamp intr roof courtesy and dual reading
D55 console frt compt floor
D64 mirror i/s rh sunshade illum
D68 mirror o/s ih&rh rem cont painted
D71 gear speedo driven
D85 stripe body side lower accent
E5Z speedo adapter delete (analog cluster only)
FE3 suspension system(sport)
GU6 axlerear 3.42 ratio
G80 posi limited slip
G87 ring gear 8.50 10 bolt axle
J41 brake system pwr frt disc rr drum castiron
J50 brake system power
K09 gen 120 amp
K34 cruise control
LC2 engine gas 6 cyl 3.8L sfI v6 turbo H.o
MW9 trans 200 4r
MXO merchandised trans auto provisions o/d
NA5 emissions system fed
NP5 steering wheel (leather wrapped)
NQ5 cap steering wheel horn deluxe
N33 steering colum tilt type
N89 wheel turbo aluminum
QYH tire 215/65/15
TL6 grill (black)
TL6 ornametation exterior hood (3.8 SFI TURBO)
TT5 headlamps halo 4
T47 hood (turbo)
T63 headlamp on warning provision system
T82 headlamps auto on/off cont
T83 headlamps dr (special)
T93 lamp tail&stop (special)
UA6 theft deterant system
UQ1 provisions for stereo
US7 antenna power painted radio
UW4 speaker system 6 dual frt dash mtd f/d dual
U23 cluster inst trim cdom
VD6 bumper provisions frt aluminum
VD7 bumper provisions rr aluminum
VK3 license plate mounting pkg
WO2 package sport appearance
Y56 merchandising package gran touring
Y56 stripe color accent two tone med gray met/black
54U primary color exterior med flax (91) yellow beige
62B trim comb light saddle cloth
62I trim int light saddle (I)
mods:
stock block billet caps, 4340 crank, scat h beam rods,and je pistons
208/208 cam
T&D 1.65 rockers
ported heads,o-ringed, and bigger valves
turbo saver biggie oil filter relocator
k&n cone filter
009 injectors
nos inline fuel pump
red armstrong volt booster and 93 chip
casper hot wire
ta-49 turbo
adjustable wastegate and fuel pressure
ATR 3" down pipe
3" test pipe with dump
cotton 3" single shot exhaust
front mount intercooler
ramcharger fans
B&M megashifter
turbo 350 trans with alto clutches and kealar band (also have 2004r)
b&m shift kit
TCI saturdaynight special converter
trans cooler
turbo cooler
torque strap
comp eng 3 way adjustable front shocks
boxed upper and lower control arms
rr air bag
kyb gas adjust 50/50 rear
poly bushings front and rear
autometer tach,oil,water temp,fuel pressure,and boost guages
scanmaster2.1
still needs body work and interior work motor fresh might have 20 miles on it
