Conventional Total Seal CR5899 will be a fine choice. If you want something fancy and a motor that seals immediately, go with the AP rings. The bore needs a special finish to run them though.
I have used the AP stainless rings since they came out years ago. Many are behind in technology and are just finding out about them. I order them with a certain coating and machine work adding a hefty extra cost. They are a tough ring to file, but worth the extra work. Always use a standard tension oil ring. I would run .022" on the top and .024" on the second. Make sure to get the radial dimensions of your piston to make sure the rings you order will work.
