THIS FILE is a run not at the track my battery died so couldn't record the run at the track ,but the setting are about the same on pl, only thing i changed was parameter #4 to 12.5 on this run.I was wondering why my afr doesn't come down closer to parameter setting, fuel press set 43# vac off and 70# at wot,i believe i can't go any further down with 12.5 on pl,should i lower fp alittle? any advice would be great,
