Anyone willing to show me their cgt files and combo info, or even a screen shot of your AF and spark tables. Had my car running pretty good, was playing this AM on the road and noticed target and actual were way off, I got it at 13.9 for idle and when I got it in the 13.2 range the car started running like ****. Seems to like it best in the 12.9 area, but I dont know about running it that rich all the time.
What are you all using for low op AF ratios, and if you';re running relatively lean, how much timing did you add to get it not to stall. I'm at 13.4 and 36* and it stalls once in awhile, richer it idles better, more timing doesnt seem to help. I went to 38* and instead of fizzling out, it just cut out. IN the real low 13's to high 12's it runs like a champ tho.
How long do your all plugs last, those running sub 13:1 AF's?
BTW, my IAC problem is the hole in the accufab TB is too small. I took the IAC out and the idle was only avout 100rpm higher than normal.
