please help i need discontinued parts....
Status
Not open for further replies.
dzan14
Hello, please help i need discontinued parts....i have a 87 t-type and i need a gasket that goes between the elbow and turbine housing, (the elbow then connects to the down pipe) was thinking about making one...
i also need a single nipple heat sensor that sits on the front right side of the intake. i am almost sure that it is my engine temp sensor.
both of these parts are discontinued and holding me back from final assembally! if some could please help i would really appreciate it. for some reason it will not allow me to upload my pics...
There wasn't a gasket between the turbine housing and the elbow.
Casper's has the fan high switch
As stated in your other post, there was no gasket that goes between the downpipe elbow and the side of the turbine housing. Most people use high temp copper silicone on those two flat surfaces.
Your coolant sensors, which ever ones they are can be had from Caspers Electronics, Kirban Performance or nos4gnparts .
Those sensors are typically also available from Napa and Autozone. Just need to specify which one you need as was previously said.
I am closing this post as it is a duplicate.
Patrick
Status
