Dr. Jeckel
- Jul 29, 2003
I have been reading numerous quotes and looking at the procedure in gnttype.org and i have a question. Where do you put the drill to turn the pump and why does just disconnecting the ecm wire and using the starter to build pressure(like when you do an oil change) not work for priming the system. Can someone help me out with this. The more posts I read the more confusing it gets. Pics or drawings would be awesome to help me associate words with the actual pieces being described. Any help is GREATLY appreciated. I changed the cam on my LS1 and reading everything about just changing the timing chain on these cars makes changing the cam in my LS1 seem like cake.
Thanks, James.
Thanks, James.
