Im having some o2 trouble. Ive tried 2 new denso sensors...but still the same issue. At idle and at regular cruising.....the o2 numbers no longer bounce around. They stay in the mid 800's. If i let off the throttle....they drop to the 000's and stay there till i get back on the gas.....then go back to the 800's. Idle just stays in the 800's. WOT o2 readings seem normal. Any input as to why my o2s are no longer bouncing around (ive tried 2 sensors) would be greatly appreciated. Thank you in advance. Chris
