I have a stumble off the line. I believe it to be a fuel delivery issue. Pay attention to 1.1 to 1.9 seconds launch was pretty hard. The fuel pressure is ramping up with boost then at 1.4-1.7 seconds the pressure drops then starts to recover as boost is rising the whole time. Pressure should have kept rising with boost. The wheels lift up drop down due to a stumble in the engine and lift back up again. The fuel pressure is ramping up with boost at launch then dips when the stumble happens then picks back up. Is that fuel pressure drop enough to be the cause of my stumble. It this possible just from the inertia of the launch pulling the towards to back of the car ? Pump is a fuelab with a ss prefilter and post filter which both are clean with a fuel cell baffled and with foam and #8 aeroquip teflon line to the fuel rail and a fuel lab regulator coming off of the fuel rail with a #6 teflon line back to the cell. The fuel pressure readings are not 100% accurate I'm fiddling with the settings in fast to make it more accurate but the pressure drop is for real. Don't pay any attention to the log after this time I broke traction and spun then had to get out of it.
Fyi We retraced all the fuel lines from cell to fuel rail and back there is not pinches tight spots questionable areas where the line is routed. 100 % sure of this.
