Greetings Folks,
A newbie to this forum is urgently seeking data about transmissions. Consider if your car meets all of the following criteria, over at least the past 50,000 miles of usage:
1.) Transmission is an automatic and has at least three forward
gears.
2.) Runs 12's or faster in street trim
3.) Runs 11's or faster on the strip
4.) Car is driven primarily on the street (majority not on highway,
however.)
5.) Car weighs at least 3,300 lb with driver
6.) Transmission hasn't been modified over period of usage.
7.) Transmission has performed absolutely flawlessly, and has
received only routine maintenance (fluid and filter.)
If your answer to all of these questions is "yes," then please
respond with the following information:
1.) What kind of transmission do you have (200-4R, for example.)
2.) What converter does it have (dia., approx. stall speed, with
or without lock-up.)
3.) Where did you get your transmssion and converter.
4.) And/or, what salient features does it have which you believe
have contributed to its performance and outstanding
reliability.
Here's my reason for asking: over the past eight years, I've killed ** six ** (now apparently going on seven) 700R-4's and 200-R4's, behind a 500hp - 500ft-lb motor. I've completely lost any faith in these tranny's being able to handle moderate power/torque with any true measure of reliability. But, I'm also hoping beyond hope that some of you may prove me wrong, in which case I'd be extremely grateful to learn from your experience (I suspect this is true for others here as well.)
Thank you very much!
Best,
MAP
gears.
however.)
reliability.
Best,
MAP
