87-TURBO-T
- Apr 16, 2009
currently i'm running a 1/2" plenum spacer. do you think its helping or hurting performance? combo in sig. thanks
SignUp Now!mike why is the spacer better with alky than the pp
While the PP works well at certain flow levels it was not designed for wet flow, I am not sure that the alky will distribute properly with one installed.
Atomized does not mean it is not there, it means fine particles of alky are suspended in the charge air making it "wet" just like the air coming through a carb the air going into the intake manifold is considered "wet" the rules for wet flow are different than dry flow
Mike
