I.....................So what do you guys think about a total 1.5 inch spacer between the intake and plenum?
You actually have 2 questions with this post, your title asks "is bigger better?", and as with many things, it most likely is better, at least to some yet un-defined level.
Even with a total spacer dimension of 1-1/2" I do not see that as an issue in your build, nor do I see it as much, if any, help with your build.
I consider the plenum volume as an air "reservoir" which feeds each cylinder as the intake valve opens. The larger volume may lessen turbulence and give a more even air flow into the cylinders? As air flow increases with RPM, the larger volume would help air flow, but even with "spirited" street driving you it may be difficult to notice any difference?
Another possible benefit with the larger volume is the incoming air charge temp would be less, but again this would be a very small gain.
My personal opinion is I want the largest plenum volume I can achieve within the physical restraints, accessibility, and still be visually appealing.
But I do not want a bird house, or small dog house, on top of my engine!
