Plumers or Well Drillers Help Needed
getchasum
MISSING 2 CYLINDERS???
If any of you guys are experienced in water wells I need some help, Please shot me a PM I'd like to ask you several questions.
I've pick up a rather large pressure washer & I'm concerned I can not flow enough water/gpm to supply my new pressure washer. I'm looking to get more flow out of my well, I'm needing a min of 5 gpm's supply.
you'll need to know what your existing pump is rated for (gpm @ psi) and then also what gpm at what psi you need. If you have the make/model on the well pump, you should be able to find out what it is capable of via the internet or the metal plate on the pump.
nate
