Sal Lubrano
- Apr 26, 2002
SignUp Now!TurboBob said:I will be installing a PLX in the near future, and will have more data on this.
But, I would not connect that "ground" connection to the ECM. What I would do is to make sure the PLX power wiring is as short as practical, and is connected to a good (engine) ground and not some body/dashboard bolt.
So I will be powering my PLX from the ignition voltage feed wire to the ECM (A6) and grounding it to one of the large black/white ground wires (A12).
Then I will only make the one analog connection as you have shown it above.
I'll post back once its installed.
Bob
oh, its a long story.
a friend liked my LC1 + XD16, so I decided to trade to something else.
TurboDave and TurboPete both have the PLX. And I got the DM6 gauge to go with the PLX.
I have some ideas for new toys in the future, and might try to talk to the PLX over the digital link.
Bob
1, that lower left corner pin in that 4 pin connector IS NOT GROUND (at least in the newer SM-AFR's), its one of the power feeds to the DM6 gauge.
2, you can get power from anywhere, the ground connection is the important one, to minimize voltage offset issues.
Bob
Bob
