SignUp Now! . My funky little s10 I painted took almost 3 weeks to buff. 1000 blocked - 1200 -blocked - 1500-blocked. Be careful, you can burn straight through the clear!!!! With the 1000 take almost all of the orange peel out, using long strokes in a criss cross pattern. I even buffed the door jambs on my s10. I will try to locate some pics. Always have the buffer rotate off of the part not onto it and go slower with lighter pressure on edges. What brand/system did you go with?
Originally posted by Red Regal T
I never use higher than 1200 grit. Doesn't seem to take anything off. May have a use, perhaps for sanding scratches, but I think it's just something to sell. If I'm doing a show job, using a lot of clear, I use 500 to start. These higher number papers, 1200 and up, have very little effect. If you don't flatten out the surface by taking off material, you'll have a finish that looks like a rolling ocean. The more clear you put on, the more paint buildup you will have. You have to make the painted surface flat, like a mirror. Did you ever look in a wavy mirror?
