I put the polymounts in my TTA about a month ago and it
wasn't that bad. However I did have my turbo, IC.,DP.,
starter, and cross over pipe off of the car at the time,which
I'm sure made it a little easier. Just take your time and follow
the instructions and you will have no problems. It is definetly
a two man job,you need someone under the car and someone
under the hood to loosen/tighten the frame pad bolts. You will
also need the special wrench supplied with the mounts and a
wobble head extension to reach some of the bolts/nuts when
you are under the car. I have a pit in my garage so that was a
big help,but I'm sure a set of car ramps or jack stands would
also work if you don't have access to a car lift or a pit. Two things
to watch for are: When you jack up the motor to get the mounts
out/in, don't go two high or you might rip a wire loose like I did
(It was just a ground cable,but it cost me a trip to the Pontiac
garage to find the problem). And don't over tighten the long bolt
that connects the mounts together,or it will smash the poly out of
shape. I did over tighten mine because the instructions gave the
wrong torque on this bolt,so I called John at John's performance
and he told me to back it off to about half the torque which I think
was about 30 lbs. They are supposed to change this in the future,
so make sure that you check your instruction sheet. If you have
any problems call John and he will walk you though it step by step. Installing the polymounts is definetly worth the trouble.
My motor sits nice and level now and doesn't move at all,plus I
have a 1/4" of clearance all the way around the DP. I didn't
notice any increase in vibration either. Good Luck.
James.
