Sorry for the length, here's the deal: 1/8 mile
Last time out (April), I ran an 8.7@79, 2.0 60' on BFG Radials. Stock wastegate, RA93 chip(makes ~17lbs boost), and my mods below EXCEPT for porting elbow. No scanmaster at the time. Basically stock at this point.
Now, I have the scanmaster, Thrasher 92, and misc minor changes like the ported elbow, adjustable WG. Temps were easily 15 to 20 degrees cooler last night. I mixed a Xylene brew, and creeped the boost up to 21 lbs, no knock, O2's in the high 700's (lowest all night was 765 or so). Traction was a big problem, but I did manage a reasonable launch on my last run and did an 8.8@79, 2.0 60 ft. 21lbs!
I'm not expecting anything fantastic with street tires, but I was reasonably sure that I could trim my ET to about 8.5 with 21lbs as long as I could cut a 2.0 60'. It is possible that it was unusually humid, tho. Do you think the Thrasher had a big impact here? Any other thoughts?
Also, it seemed like I crept the boost up all night and never gained any ground. Run #2 was at about 18 lbs, also an 8.8@79????
Thanks.
Thanks.
