Alright, after having the Service Engine light come on it was a Malfunction code 22. The TPS sensor was dead. I ordered a new TPS from Kirban and installed it. I got the volts on idle at .42 but I couldnt get the WOT at its correct settings. Started up the car and the Service Engine light went away as well as the Malfunction code on the Scan Master. So I thought all was good. I bought E3.42 Spark plugs and changed them out. (The old ones were black from running rich). In the process I must of changed the firing order because when I took the car out for a run, there was a popping noise coming from the exhaust. There was alot of movement in the engine (car shaky). And when the turbo was trying to spool up, it didnt. Just alot of sputtering noise. I immediately brought the car back home. I took readings of the ScanMaster in the idle position. Could it be that the TPS is set wrong? Incorrect order of spark plug wires? Any help would be appreciated.
02 V- 300 TO 600
AF- 8
L8- 62
BAT 13.3
INT- 120
BL- 155
CLT- 154
ATS- 130
R- 700
TPS- .42
IAC- 77
CC-124
MAL- 00
02 V- 300 TO 600
AF- 8
L8- 62
BAT 13.3
INT- 120
BL- 155
CLT- 154
ATS- 130
R- 700
TPS- .42
IAC- 77
CC-124
MAL- 00
