boostmaster
- Aug 20, 2001
Flow
All I can say is that on the flow sheet recieved with my heads the numbers were very similar to Esingers and they flowed good enough to propel Lee Thompsons car to bottom 11's high 10's although I thought the numbers were quite low too till I did some research on head flow variances. So Jerryl if those numbers are accurate man you should be runnin!!!!!! after you put those on.
Agree 200%![]()
I also realize it is not just about flow, and there is MUCH more involved.
All I was trying to say is that stock heads are rated around 160 (If I recall correctly), so I would expect much better numbers than 175 on the intake on just about any ported head.![]()
