If the proper parts were used with the heads and the tune was good there is over 150hp potential increase. If you had a 76 or 65 trim turbo and the car went 11.2@25psi it would likely go 10.7 with heads and cam at the same boost. The intake only needs a quick cleanup around the port exit and it will outflow the heads.
