I'm sorry, I didn't measure it. I know it was offset to the Puck from Precision as you can see in the first photo. I do have the 1/8th inch sealing surface and radiused the hole in the housing. Put it on the car with a stock long block except for 206 cam and JE pistons and it was solid at 18-19 psi. No complaints since its an alky car. You need to mount the Turbo to the downpipe to mark the Puck. Don't guess or you may offset the two and cause an internal leak.
