Porting a stock throttle body and dog house
Reggie West
TurboBuick.Com Supporter!
Is anyone doing this still?
I need to port both out using the stock throttle body and dog house.
Or is Accufab my only option for a 70 mm throttle body? They do not make the slanted dog house anymore.
You can get a 65mm from them, which is the same as a ported stock one.
Forged stroker motor with ported steel heads. 224 cam, 68/67 Q trim 3 Bolt running on E85.
So as far as the trans will let it. Low 10s high 9s.
steve is very good, he used to have them in stock,
I have one , it bumped the hp from 575 to 620 RWHP.
no other changes, (other than tune)
Steve is great. Turn around was super quick too. Highly recommended. Excellent workmanship.
Steve did mine last year, fast turnaround, looked brand new when returned
Sent from my XT1254 using Tapatalk
I went with Steve from throttlebodys.com this afternoon.
I wish you had piped in sooner I would have hit you up for it.
Yea I already have all my porting stuff out . I started on my TA SE heads for my stage motor.
Anyone have experience using his ported TB and dealing with CA. smog ?
I would have helped you out also had I seen this thread sooner.
I have a Brand new 65mm Hemco or a 70mm Kenne Bell/Accufab that I could have let you try out.
