SignUp Now!Take it easy on Bart...LOL
O Lord! He still hasn't spoke/called since then..lol U hear what Scott ran his first time out on the small motor?
Can you elaborate on this a little more? I would like to understand this better. I haven't really understood when this needs to be done or when it doesn't. Im running a stock turbo but I'm planning on building a new down pipe. I noticed a lot of downpipes have a extra large puck in them for ported holes. When i build my downpipe I was considering adding a extra large puck as well, but I don't really know why I would need it, or what effect it would have to increase the size of this hole. I plan on going to a te44 turbo in the future.Boost control...stock turbo doesnt need it
That is exactly what I was doing when I was reading about porting the waste gate. Thanks for the info.Bit of advice...... take the time and do research on areas and stuff your curious about the board here has a ton of info.
I thnk thats whats going on with mine. Its ported so much theres a spot where it looks like exhaust is blowing past the puck (lmk what you think Bison). When I still had the stock turbo on my car I did experience some boost creep. A mbc fixed that problem. Made the car fun as hell on the street too.If the turbo is selected based on a target horsepower (mass flow) and the target hp is close to the maximum mass flow of the turbo little to no porting of the hole is needed. If you over do it you just made it easier for the ex pressure to push it open and can expect boost drop off when you start working it up near it's potential. I still have never needed to go larger than 1.1" on anything I've done
