Powder coating fun
87gnttop1
Moved this to the how to section so you can show how you did it as a step by step guide for others.;)
He's saying he moved it for you. Btw nice work! What equipment do you use?
I'm using a east wood kit with a homemade oven ill have pics on the the equipment and process tomorrow morning
My gun
Home made oven
Cooling plate I sanded down with 220grit and acid washed to take off the rust that I couldn't get to
Then I washed and wiped down with a little paint thinner
Made sure it was clean and preheated the cooling plate before applying powder
I applied a pretty thick coat because I know I might scrach it up a little because its always in the way
Are those just two normal oven elements on the bottom for your heat source? I also use the Eastwood kit and an old 220v oven, but want to make a larger oven to be able to do bumpers and diffs. Any gasket for the door seal?
Yes there oven elements and we welded the bottom then added fire proof I believe it's fiberglass insulation all around my buddy got the material but also made a hanging rack
With the ground attached to it I think it works better were in the process of building another oven ill make sure ill do the step by step so u see how we're going to make it
With out a ground the electo-static part of powder coating is out the window. It can still cover but you will use twice as much powder trying to get it that way. And more ( thicker) is not always better.
Good luck looks like a good start.
I see that you powder coated the inside of the intake . Is that a good idea ? I'm thinking of powdercoating mine , just wanted to know
Not the best idea.....most people , when they start do then the more they learn and powder the more prep and masking they do.
Well I did it to smoothen out the runners I did my research on it
