- Mar 1, 2013
So my factory power antenna crapped out in my. Would run and run but no movement, so another member happened to be selling still new in package a power antenna. And now this one is acting stupid! I wasn't to thrill about the idea of pulling on my fender the way I did the first time, let alone a second time. What does everyone else do? Just disconnect the wire for power antenna? Do you still get signal? Do they still make windshields with the antenna built in? Cause I won't think twice about ripping that damned thing out and welding up that hole prior to paint. I even sprayed WD-40 down the hole just to make sure it worked effortless. [emoji849][emoji379]
