Power Antenna Relay
What is the problem? If the ant. doesn't stop running, I believe kirban's sells a repair kit or one of our vendors does.
The antenna is controlled by two limit switches in the ant. itself. and protected by a fuse.(5 amp.)
I stand corrected, I did find a relay on the right side of the glove compartment. A pink wire from the radio and an orange wire from the cig. ltr fuse. Can check power at connector to ant. w/wht, org, and grey wire to ant. under hood. There is a grd wire attached to the frame below the glove box you can trace back to the relay.
