Power Logger knock counts vs. Caspers gauge
Correct. the parameter you want to change is the "BLM correction" parameter 11. Since you're BLM numbers are showing about 10% rich you'll want to decrease parameter 11 by 3.
I'm wondering if your NB O2 is way off also. It's surprising that the BLM is only 10-12 counts low and still well within adjustability, for some reason that cell isn't "learning".
Something is amiss somewhere.
It's a new NB 02. I just installed it the other day. Most of the BLM cells are in that range. From my experience with this chip, raising or lowering the BLMS usually makes a noticable difference. It's worth a try.
My WBAF ratio is about 11:1 at WOT. Is that too lean?
Depends on whether or not you're running alky. No alky; 11:1 is just a tad rich (although safe). alky; 11:1 is just a teeny bit lean (although safe).
I try running 11.5:1 with (no alky). seems safe, 20# no knock, 93 octane.
Did you figure out your knock gauge problem? I'll dealing with something similar.
