Power Logger Questions
65malibuss
1. Where are the recorded files stored? I would like to be able to email files to fellow power logger users to compare data.
2. How do you get the auto record function to work? I have the TPS box checked but it won't record my runs unless I hit the spacebar first.
3. Is it possible to export the data into a spreadsheet?
Thanks.
Thanks.
after you record a run, it exists in memory, you have to save it (F3...S)
Then you get to choose where it goes. And add a file comment. Quick-save or auto-save will be added in the future.
It should auto record, what is the mion time set to?
Export to CSV will be added in the future.
Bob
Okay I found the files they are in My Documents.
I had both the TPS and Knock boxes checked which I guess means both need to be satisfied, so I unchecked the Knock box.
Thanks.
