Edit: I'm just going to make this my car's 'build' thread.
I pulled the engine over the weekend due to a leaky rear main. The engine ran well and this is my first motor pull. I plan on changing as many seals as possible and cleaning up the engine since it looks like an ecological disaster with the oil leak. I don't plan on any major upgrades but I do plan the following:
Looking for your input and suggestions on what you'd do.
I had a buddy already give me one good tip I probably wouldn't have done unless he suggested it. He said don't flip the motor over to unbolt the oil pan on the stand due to a chance of debris. It makes perfect since and I wouldn't have done that so I'm glad he suggested it.
Any tips would be great, I'll take some pics and share as I go. I already have some I'll post soon.
- change out stock timing gear (research shows can't go wrong with the TA one though expensive)
- replace seals (open to your suggestions on where to buy, are kits available?)
- powdercoat, powdercoat, powdercoat. (i'm ordering the eastwood gun, got pics of your engines?)
- since the engine is out I plan on swapping the steering shaft to the jeep version. (got one for sale?)
- clean off the undercoating. (original owner LOVED Zeibart, its awlful, any tips on it's removal?)
- replace faulty ac compressor. (got a recommendation?, if not I'll search)
- Replace powersteering pump. (mine has a slight whine)
- perhaps run new transmission cooling lines since they're a pain anyway.
- reroute and/or replace engine harness. (I really want a cleaner engine bay)
- would like to clean up the firewall some (tips?)
