SignUp Now!From what I have heard. Buick put smaller window motors in to save on weight.![]()
going on a1electric.com, which offers a power window kit for the 79-87 g-bodies. It is my understanding that this kit, originally for mod'g manual windows to power, brings the window up to present day speed. another alternative is to purchase the replacement window motors from either advance auto or auto zone which are supposedly much faster than stock at around $55.00 each, depending on what part of the country your in. when I priced mine they were $59.00.![]()
Do the A1electric kits work with concert sound? I have a set of the older G-body motors/regs, but couldn't get them to fit with the concert sound door speakers...
So in conclusion here, as long as I have at least 12V of juice going to the windows and possibly new aftermarket motors, I should be in good shape, correct?
Look, when it rains it takes about 30 seconds to roll up the windows, which in my opinion is too long.
Nick
It aint the motors that are at fault. Make sure you have enough voltage going to them. You can check the load at the big pink wire on the fuse block. If aint got at least 12V there than you need to fix that first.
Sorry, the motors are crap.![]()
My original T-Type pass window is so slow [and has been since new 1986] that you can eat lunch while it goes up.
The earlier G-bodies used a different regulator and motor that was spring-assisted, and it is not an easy change-over.
Eric,
Let me know the story. As I need faster power windows!!!!
Nick
