Powerband
fmster
Hi to all! Ok here is my senerio,when I part throtle my car the car thrust foward pretty good.But when I wot the car it winds and it feels like the boost is behind the power band. The engine has less than 5k:confused:
40 over block edelbrock 204,214 cam,lifters and timing chain,ported to match throtle body,turbo,intake,heads.Heads shaved 030,lt1 valve springs,87 coil,module,ecm tt chip,dual fans,F body rad,walbro 307 with out a hotwire.
Shift kit
Yes I have a scan tool, it's an old school OTC scaner .I have the boost at 10lbs any thing more and it knocks!
First thing I'd do is hot wire the Walbro, and find a way to monitor pressure at WOT. You should be able to boost over 10psi without knock... Are you reading any KR at FT?
Problem solved
Ok I hotwired in the fuel pump and now is pushing hard at wot.I also raised the boost. Thanks
