TURBOPOWERED68
David
- Jan 31, 2006
I just installed an LC1 WB unit on my car and have a few questions.
the LC1 i have does NOT have a gauge with it so all my readings will be off of the scanmaster and PL.
on the PL's Configurations page i set the Wide Band input to = LC1, Smoothing = none, volts = didn't change anything.
i connected the Brown wire from the LC1 to the PL's L1 input.
with the car running the wide band reading stays unmoved at 7.36
i don't have that stupid serial to USB adopter cable so i can directly see what the LC1 is doing or not doing.
But i did read on the LC1 manual that the preset settings on the Brown wire out are "Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39"
Yes once i get the Wire for the LC1 i will check to make sure that the settings are all good.
thanks for any input you guys can offer.
