achalmersman
- May 28, 2012
I have not given up yet
Steve, can you post a log just so we can verify your issue is the same as LilTruck and I?
As Red on the old Red Green show used to say, "were all in this together"
I don't have any saved ones, but I will get one. I will also get the ar133's out of there as well.Steve, can you post a log just so we can verify your issue is the same as LilTruck and I?
As Red on the old Red Green show used to say, "were all in this together"![]()
I have to ask. Are you the "one case that never could get it to work" car that Eric told me about?
My exact point in one of my comments earlier... You hit the nail on the head.... High dollar substitutes aren't " fixes ".....Xfi isn't a "fix". Its a substitute. That's like fixing a blown HG with a new aluminum S2 engine. I'm not going to do that. Again, my car, nor myself is ready for that leap. Let alone my checkbook
The cars that the TR6 fixed: did it fix a common sputter / miss at WOT commonly associated with bad ignition parts on these cars? That's not the issue here. The logs show this is not a traditional weak coil / module issue. Not saying they can't create interference which may be causing my issue, but its not just traditional weak ignition symptoms.
I will be taking the autolites out and installing NGK YR5 tomorrow night hopefully and testing as well assuming the roads here dry up.is everyone running the autolite's? I never had this issues prior to autolites but I also changed to e85 when I started running them. the car did run fine on the autolites so Im not suspecting the, but I did go back to NGK and I still had the issue so I put autolites back in.
Will do I order some plugs lastnite, hopefully I will have them by thanksgiving.Hey Steve V get those AR 133's out of there and let's see if we have 2 fixed cars!
Right now I don't care. I would ASSume the hardware portion of the chip (is it a Motorola chip Eric?) would be just as susceptible to interference as the other. If the problem is indeed fixed and the plugs don't fix Steve V car then I guess I can put the 5.6 chip back in and see if the problem returns. I seriously doubt it was the chip thoughSo you did the new chip and plugs at the same time? Which one fixed it? That's if it is fixed ...
Popcorn
