PowerLogger GURU help needed (AEM Boost Gauge)
sakudog
I'm trying to interface the PowerLogger to an 35psi AEM Boost Gauge
Here are the essential features of the gauge:
http://www.aemelectronics.com/boost...og-face-774?osCsid=m2f0ri6bju44ohp549ep30q6o2
I've attached the analog out (white wire) to input 2 on the power logger and set the input configuration to 3.5 bar but it just reads boost. The powerlogger is showing roughly 2.05 volts at idle which on the 3.5 bar map setting reads to be 4.8-5psi which the gauge is displaying -19 inch/hg.
Is there a known specific setting for the AEM Boost gauge's 5volt analog output that I can edit in an INI file somewhere to make this work correctly??
OK, after a deeper read of the AEM instructions.... the - analog output if not hooked up to some AEM device, needs to be grounded, and after grounding the brown wire it seems to be reading correct. :)
Yes, I drove this whole thread and answered my own questions by simply reading the instructions!!! LOL maybe this will help someone else in the future? :)
