Powerlogger MAP/Boost signal for the TTA??
NCTURBOS
Gettin' back in action!!
Staff member
On the Regals there is an easy wiring tap behind the glovebox for allowing to datalog the MAP/boost signal when running the Powerlogger. Is there also just as easy a way to tap the MAP/bost signal for the TTA?
Thanks,
K.
There is a connector behind the instrument cluster.. typically accessed when pulling the cluster.
Easier to tap it under the hood. If the car has an alky kit.. tap into the green wire going to the kit.
I tapped mine there too. I originally had it at the MAP too. But like it under the dash better. But both work. :p
