Rosey1968
- Mar 31, 2017
So I got my Powerlogger hooked up and attached is my first data file. This was done at idle. I have not had the car on the road yet this spring.
My fule pressure is not recording and I do not have a wideband (yet). Need to figure out why FP is not coming through the Input 4 connection.
I have a TT 5.6 Alchy chip and the rest should be in my signature below.
The issue I am haveing with the car is that once I go into closed loop it stumbles and wants to die. I have had this issue since last fall. That is at frame 1090.
Over the winter I have installed the TR6 ignition, capser ground stretcher kit, postivie battery cable kit, new injectors, new MAF. All of this was planned before my stuble issue.
I did have my throttle body serviced and modified by Steve Monroe.
Being new to the PL and still learing... what is my problem. Is this s TPS/IAC adjustment issue or somehting esle.
Thanks.
Thanks.
