Powerlogger questions?
turbojitsu85
I'm going to be buying a Powerlogger from a friend and have a few questions about how to use it. I'm running Vista and I've downloaded the Powerlogger program from Full Throttles website just to see how it works. I believe I've downloaded everything and updated the right drivers. I downloaded a file someone posted and I can't seem to figure out how to play it. I'm thinking I either didn't download the right stuff of I'm not loading the file properly. Can someone run me threw how to playback the files? OK I read the manual again a little slower this time and figured it out.
Is boost sensing come from the stock sensor connected to the ECM or do I need an aftermarket boostsensing harness?
My other question is has anyone used powerlogger on a Windows 7 machine yet?
You can use the factory map sensor, or change to a 3 bar map sensor. You will need to wire it in. Go to the full throttle site and its explained there. The lastest version of the powerlogger is listed on my link below also.
