Powerlogger run - thoughts?
cuda6pak
Finally got around to datalogging a quick WOT run....didn't run it quite as high as I wanted. This is with the mods in my sig set at 10.4 target A/F...psi(4) is fuel pressure. Should be hitting a dyno soon to really see where she's at.
log looks good. is that a WB chip? i dont see it tracking. with a WB chip and setting the a/f it might run a air better. i would also lean it out some, your on the fat side for sure
Yes it is with a wideband chip with AFR tracking set at 10.4 for WOT 2nd & 3rd. I was kinda shocked to see the pressures and AFR bouncing around quite a bit, maybe I need to input some smoothing in the setup? All my gauges show it rock solid with no fluctuating.
i dont see it tracking at all. i see zero corrrection happening
Correction is on, it can be monitored by looking at the BLM. However, you don't have the target set to 10.4, you have 10.8, 10.5, 10.5.
i see it in the BLM but why is the correction showing -99.2 in the a/f correction table?
