Recieved a new (rebuilt) powermaster brake unit from Kirban this week and got the unit bolted up. I put fluid into the resevior and let it sit to drain through to the lines. Made sure there was plenty of fluid still in there, connected electrical and switch the car to "ON", heard the pump working and then shut off. So I figured I start at the front driver side and bled the system, since i also changed the front flex lines to the calipers as well. There also apears to be fluid leaking from the pump??? is it me or could this unit be defective??? They say they are bench tested so....???
With the car switched "ON", every time i press the brake pedal the pump kicks on and any little pressure i did feel in the pedal is gone completely, even though the lines were bled. I went back and bled the lines again only to no avail.
On a side note, since i never had the need to watch the brake unit while pressing the brake pedal, is it normal for the fluid in the resevior to be bubbling around while pressing the brake pedal, or does that mean that there is still lots of air in the system?
never did an istall of one of these before, so i'm looking for any feedback about this
thanks
-dan
thanks
-dan
