guys please help, driving on the highway for about 1/2 hour, get off to exit and no power assist for the breaks, luckily no one in front of me....scary.....baby the car home and find that the 30 amp fuse has blown....check around the powermaster unit and there is a trace of fluid on the passenger side (maybe dripped off when i clumsily removed top of unit) anyway i replace fuse and turn on the key, unit charges but draws down about 3 ounces of fluid on the passenger half, i refill, test drive and everything fine, car stops perfectly, no sign of fluid anywhere, checked line etc. What gives? Fuses rarely blow without reason and break fluid does not vanish into thin air! Any thoughts.....please respond.....kinda scared to drive it. also, how much do you fill the resevoir? the car is a 30k rarely driven gn...i did replace the accumulator ball about two years ago. thanks
