I put a new Powermaster motor on my 1987 TR, along with a new(Grey)GM switch and a new, yellow stripe, accumulator ball. I have driven my 1887 TR less than 500 miles since I had replaced these items. However a few days ago, my brakes went out while driving and the brake pedal got hard.
I first checked the Powermaster 30amp fuse-and, it was blown. Next, I disconnected the coolant fan delay relay, installed a new fuse and then checked the operation of the powermaster brake motor. I depressed the brake pedal off and on several times with the key on and the car in my garage. The motor ran fine and the 30 amp fuse didn't blow! However, the motor became fairly hot-so, I didn't run the Powermaster motor any longer. However, the problem I noticed, was that the reservoir at the rear(Towards the firewall)was not being pumped out of the reservoir at at(The fluid level remained normal, the whole time!)? What would be the reason that with the 30 amp fuse blowing before, that the Powermaster pump would have lost it's prime? Or, is it likely, that the pump could then start pumping again, if I should prime it and then try it again to see if it will pump? It doesn't seem logical that the pump should just fail by itself, in less than 500 miles on a new(Not rebuilt!)Powermaster motor, does it?
Please indicate what steps I should take from this point? And your ideas as to the reason for the pump not pumping? And, offer anything else that I should know about this problem, I've indicated above? If you have a good proceedure for effectively, priming the Powermaster motor pump-then, I'd appreciate this information, very much? Thanks!
