Pre-Bent Brake Lines for 9" Rear Drum to Drum?
SPower6
Need to find a source for Pre-Bent Brake Lines for my Ford 9" Rear (Drum to Drum)? Please let me know if someone sells a kit or something...?
Thanks!
Jeff, How ya doin?Is the T/A on the road yet?I would call summit or jegs maybe they have them just a thought .:D
Brake lines
Try Fine Lines Inc. They even make kits to redo an entire car! Stainless steel is also available!
I have been using them for years for my restoration projects. If you don't see what you need on the web site, give them a call with measurements in hand. they should be able to help you.
GOOD PEOPLE!!:cool:
The web address is: www.finelinesinc.com
Good luck, Vic:D
Hey Wes!
Hey Wes!
Doing OK thanks! TTA been on and off the road a few times :) Should be back in action by the end of Feb... Hope all is well with you and yours. Have a gr8 New Year!
Best regards,
Jeff
Re: Brake lines
GOOD PEOPLE!!:cool:
Good luck, Vic:D
Hey Vic-
Thanks a lot for your reply and suggestion. Have a gr8 day!
Later,
Jeff
I was just getting ready to say Fine Lines,I had them do my transmission lines,they copied them off the old ones.I'm sure if they don't make them they will for you
Good people,Kinda $$$ though:D
Good luck
JW
Good luck
JW
Thanks also for your reply!
Regards,
Jeff
