Precision TA 64!!!
boost86
I can get one at a good price looking at putting it on my 86 Tt wondering if anyone has one on there car now. How do you like it what stall you are running. And is it a direct bolt on??? also any number would be great
I believe Dusty Bradford ran this turbo in TSS for a while.
K.
I did run this on my TSS car for several years. I had a 3400 non lock converter and it spooled pretty well. If it's a Q trim with the .85 housing then it will be to big for a stock motor. You can run it but it will be slow to spool. It was enough turbo to go 10.40's at 128 on my 3650# car.
It has a 4 inch inlet bell that will require an angle adapter from champion heads to relocate your IAC valve. So you will also need a 4" to 3" hose if your running a 3 inch MAF pipe.
