SignUp Now!.....snip......We have spent the last 3 years Beta testing these units in the field for reliability and durability and they passed with flying colors.....snip.....
Patrick
Has there been any testing on a car with these new turbos?
SW.
Sounds like a good idea just not sure of the durability compared to the old journal beraring turbo's.See above....I gather they haven't had any issues...... which was my initial question (in my mind when I first read about them) as well...... sounds promising?
Great info Patrick......
Will the upgrade to the H housing yield any real world differences at the 650hp range.... like bottom 10 sec... high 9 sec range? Just trying to decide if I should get the H housing or not....
What about the exhaust housing? What options are there and what is the difference in recommended stall? Mine is a 95% street car....
If you intend to play in the 25-32psi range, then yes, opt for the H cover.
If never above 25, then no. Not that much gain. But at high boost levels, charge temps would start to play a role in performance. Exactly how much depends.
Most all Buick applications offer .63 and .85 A/R turbine housings. If 95% street car and wanting the quickest spool up possible, go .63 A/R. If max out track only race car, always go .85 A/R. Almost all HPQ turbine wheel equipped turbos come standard with the .85 A/R housing. I think in all my time here, I've only ever spec'd one turbo with a .63 A/R housing for a HPQ turbine wheel equipped turbo.
HTH
Patrick
What would be the correct part number for:
1.) 6765 ACBB with the standard compressor housing? What housing is the "std" housing (inlet size and outlet size)?
2.) 6765 ACBB with the H cover (4"/3")
Both turbos with the Precision .63 exhaust housing....
Sorry.....OT - but can I purchase a H cover for my TE-45A? What is the right part number for that?
Any updates on bigger versions?
We just started shipping these new air cooled dual ball bearing cartridges out. These are dimensionally the same as the standard T3/T4 dbb units.
Here's the info on them.
"Precision Turbo Dual Ceramic Ball Bearing Turbocharger
These units feature an air-cooled, ball bearing center housing rotating assembly. Dual, angular contact ceramic ball bearings are utilized for maximum durability and an increased thrust load. These units require the use of a 1/8” NPT to -4 AN male fitting on the oil feed side, which can be purchased separately from Precision Turbo (PFT047-3039). At this time, we do not feel it is necessary to use an external oil feed restrictor fitting. At the minimum, we recommend the use of a -10AN oil drain flange/line. This flange can be purchased separately from Precision Turbo (PTP074-2008). Water cooling is not required on these units.
***This unit has been sealed for quality purposes. Do not remove the factory oil feed restrictor fitting, or damage may result***
If you have questions about this, or any of our other products, please contact us directly at (219) 996-7832."
We are currently shipping these chras with turbos that have the 57mm and 65mm turbine wheels. This includes the 6765 turbo. We have spent the last 3 years Beta testing these units in the field for reliability and durability and they passed with flying colors. The 6262, HPQ and HPS turbine wheel equipped turbos are to follow shortly. I will keep everyone up to date on those as well. Here is a pic of the new cartridge.
Also, pricing is the same for these new cartridges.
Let us know if you have any questions.
Patrick
Does anyone know what the minimum / maximum oil pressure should be using a -3AN oil feedline with these ceramic bearing turbos? .....john
