SignUp Now!I was told that GM will be releasing a carb intake with injector bungs for the LSX heads. The ET peformance heads are bad a$$. The ones I wanted were $7500 for bare castings!!
If you need an Edelbrock intake, I have one I won't be using. It's setup for stock cathedral style heads.
So those are close to $10,000 heads when all said and done. Yikes! They do nice work tho. Cal how will the LSX heads compare?
and yall keep saying "I'm going to SBC because it's cheaper" 10g's on a set of heads is a lot more than a set of GN1R's, TA's, or a set of stage 2 heads.![]()
It's too soon to tell. I'm sure the ET heads will be better, but they probably cost 6-7 times as much
Cal, which heads are these?
The ET heads I'm looking at are 2995+, depending on what options you ask for.
I believe they are the ETP CANTED VALVE heads but im not sure.
