ok here's what happened. i was out crusin last night, car was running great normal day to day thing. i was headed home and the car suddenly started sputtering bad! every time i would give it a little bit of gas it would sputter then back fire. so i legged it to the nearest parking lot to check it out. fuel was good, i started it again it started up. rev it a little and its fine again. so i let it run a little longer and not even a minute the car started again. this time i can't even drive it. it would sputter and die. checked gas and gas was full, checked fuel pressure and it was good, towed it home and checked fuel filter, pump out put inlet and outlet and was good. no codes by the way. i even tried resetting the ecm and nothing, still the same. i'll turn it off for a little bit and start it again and will run good for a minute and it starts again, wide band is showing lean while sputtering, and no codes. can this be a cam sensor problem?
help out please i'm stumped.
