paintitblack
- Feb 9, 2009
I need help cuz i'm pulling my hair out. I've done a complete 86/87 swap into my 85 T. I've got everything done and ready to fire it up but I have no power to anything on the motor and the service engine soon light and the fuel pump dont come on. Everything else works lights, windows, aftermarket guages, so on and so on. The starting system works and the motor cranks. I checked the power to the computer and it has 12v. The factory manual said to check ignition voltage to the ecm with the key on and I got nothing. All the fuses are good and have power going thru them all. I checked the fusible links coming off the starter and their all good. I don't know if I need to run extra wires in this swap or maybe I have a bad ecm. Also my digital dash isn't working , I wonder if this is related or a completely seperate problem. I moved the battery to the trunk but I have all the required wires run and all the correct grounds connected. I hope you guys have a answer cuz i'm stumped. I'm not online very much so i'm slow to respond but I will check regulary if somebody needs information. Thanks Brian
