Turbo V6 231
weekend warrior
- Jun 14, 2007
I need help ,I changed the fluid on my fairly stock t-type with over100k on the life,(by the way just purchsed it about 1 year ago and don't know the history of the car)and since changing the trans fluid and filter and cleaning up the pan,the trans is not shifting through the 1-2 gears,when I smash the pedal to the floor,but when I casual drive down the street it will shift but at high rpm and sloppy and sometimes when I step on the pedal and get off it quick,then it shifts,I tried the tv cable but nothing, people tell me that is only for 2-3 and upper gears not the 1-2 shift,it does go through the other gears and will pull strong in the upper gears but no luck from 1-2 motor just revs like iut is going to explode,and jerks the car back and forth,I just am looking to see if anyone has had this problem,or if my trans is just going or maybe a converter issue or something,can someone please help this is a problem thats really bugging me??can't trust just any trans shop to check it for me.
Thanks Brian
Thanks Brian
