Production Block Solid Roller Lifters
Try TA performance unless you want to bush the lifter bores.
I have a set of Crane lifters that will work for you new in box.......
i'll get you some pics when I can..........68512 i think is the number shielded foot lifters, whats your max lift?
Sorry they won;t work for you good up to about 540 lift only they will leak oil on the high lift..you need the crower lifters, as they have a higher oil shielded area.
Ok, I'll keep that in mind as I might be having the cam reground if I can find out the LSA and if it's worth it.
Unless someone has a production head, odd fire, solid roller cam laying around; I think I'm going to be going solid flat tappet just on entry cost and how really unworkable the cam I have is.
Thanks,
Thanks,
I've got them. Message me what you are looking to do.
