Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
cool, thanks, ill give it a try and post back
Slow down, and go back and read post #6.
SignUp Now!cool, thanks, ill give it a try and post back
I really cant afford a scan tool right now, but the ECM isnt throwing any codes, I have air, fuel, and spark, so what would the scanner do for me? the car will run if i give it gas while cranking, but it runs like junk. I would really like to get a scanner, i just cant afford it yet, is there any way around it for now?
Ok, so I found 4.8xx volts at the TPS when it was closed, and .810 volts when it was at WOT. This is what happened last time when I swapped the TPS out with one from Jays GN. I also unplugged the MAF sensor, and the car still wouldn't start. I forgot to plug it back in before I checked for codes, and all I got was code 12. shouldnt the MAF throw a code if its unplugged? What about the TPS? i know code 12 is supposed to be there when the car is off. Where should I go from here?
this is looking at it from the drivers side fender, the lever is to the left, so this is the 84/85, why would my voltages be reversed? i couldnt get the pic to paste because i took it from my cell and emailed it so it is attached. thank you.
What's up with the two wire nuts?? Could you...(or someone)...have reversed the 12v and the ground to the sensor?? This would reverse the polarity in the circuit to the sensor....
right, just about all sensors get the 5V reference voltage, but what is flood mode? I dont understand why/how A TPS sensor is preventing the car from running, I believe you, but could you explain how that works?
