WH1_T-Type
- Jun 1, 2009
Just installed a FTS chip w/60# injectors and noticed that when I am accelerating at a 'normal' rate (as in if it wasn't a T-type
) with the pedal probably a bit less the 1/4 I hear a 'ringing' sound that maintains the entire time through that throttle postion and then goes away once I'm past it. It comes back at about 3/4 maybe a bit higher and no idea if it is at WOT because...well...if it is there it is drowned out at that point!
I also have a GEN II with the plug and play harness in it and I verified that all the connections are seated properly. Anyone had this before? Any thoughts?
